1 - 18 of 18 Posts
not anymore 2007 Lexus ES350
I am thinking if getting a Wood Grain Shifter nob from Ebay for 25 bucks
but is it hard to remove the old nob how do i do that
thank you
1997 SLS
On the older Sevilles, there's a small U shaped clip embedded in the back of the shifter handle that you pry out with a fine-bladed screw driver, but I've read here that on newer Sevilles, you just pull up on the knob. Probably set the shifter first to "D" so it's straight up. If you have the clip, there will be a small cleave in the back of the handle.
i dont see anything on where to use a screw driver for the nob and if i put it in Drive id be afred to role away becous ehte Parking break releas when the car is taken out of park
1997 SLS
Put the key in the ignition and turn it to "on" but do not start the car. Now with your foot on the brake, put the shifter into "1". Look at the back of the knob about 1 inch up from the base. If you see a horizontal slit, you have the clip. If not, I've read here that you just pull the knob off. If someone here knows differently, please assist.
2003 Cadillac Seville STS 73k Miles, '90 Chevy 1500 Reg Cab
Correct, if you dont' have the slit in it its just held in place with a spring clip, now warning, it takes a fair amount of force to pull it off so be wary of hitting yourself in the head.
wondering if i sprayed some sort of a liquid wrench under the nob or somthing like that if it would be bad or help move it off easier
It will make your hand slippery, other than that … nothing.
Here is my thread about the shifter knob removal, is mainly about the pre ’98 model but peoples described their experience with the post ’97 knobs in few posts.
Cadillac Technician
none
Don't spray anything, just eat some Wheaties and don't smack yourself in the face.
There is a clip in there that likes to hang on.
You have to pull like you wouldn't believe but it will come off.
This is if it is the inverted teardrop design. If it is a T handle it will have a pin in it somewhere as noted above.
Discussion Starter · #11 ·
no not the T its the big one that looks like a thubs sticking up
Just so there is no confusion:
1. Pre ’96 shifter knob (also referred as “T” knob)
2. ‘96-’97 (Seville) ‘96-’02 (Eldorado) shifter knob (I saw it referred as cobra head knob)
3. ’98 – ’03 (Seville) and ~’99 – up Deville woodgrain shifter knob
3.1. Also available in leather (up to ~’01)
First 2 have the horseshoe clip (in front bellow the button) the other two have an internal spring-loaded clip.
I'm guessing that the "T" and Cobra types are the ones with the clip embedded in the back.
Exactly :highfive: the so called “horseshoe” clip, and by “back” you understand the driver’s point of view, because in reality the clip is in the front of the knob (towards the front of the car), but that’s just a technicality.
1 - 18 of 18 Posts
