Before I had the car serviced and the meter reset I also hit 1.04 R and 1.08 or so L running G3D3's. However this was only while turning rapidly on a hill. I can not replicate those numbers on a flat surface. The best I have done on a flat surface is 0.96. I suspect the G-force meter somehow can be tricked slightly by the cominbation of vertical and horizontal forces. Still, 0.96 on nearly shot tires and outside temps of 70 degrees is pretty impressive or this 4000lbs car. I keep the tires a little overinflated as well.
