Installed the Hotchkis sway bars, and all I can say is wow. Tremendous difference. The car handles like it is on a track. Almost no body roll what so ever. A little tricky to get the bars on, but I am extremely happy with it.
2017 CTS-V
Awesome! Are you still running the stock springs?
I'm hoping to get the sways installed on mine by the end of november when I have a spare weekend. How long did it take you and do you mind sharing some of the tricks involved?
2003 Cadillac CTS, 2005 Cadillac STS4 1SG
I'm curious also, let us kno.
yes, stock springs. i have not installed the hotchkis springs yet. The front sway was pretty straight forward, jack it up, pull off the wheels, make sure you put the bar in the right direction or you will be scratching your head since it wont line up.(yes i did that lol). For the rear, you have to basically unhook the hangers on the exhaust, to drop it a little, so the bars can be swaped. ***a little advice--be careful with the swaybar endlinks. You need to insert an allen key into the end, then turn the bolt off with a 15mm wrench. when under the car, this is a pretty nasty task. Yea i mangled one up and broke it, so i had to buy a new one from the dealer.($39) There is 2 in the front, and 2 in the rear. Be gentle lol.
2017 CTS-V
CTS V6 3.6 said:
it should take probably 2 hours or so for the sways. The springs should take longer.
Wow, 2 hours. That's not bad at all! It took me 6 or 7 hours to do the springs but that's cuz I couldn't figure out what the service manual was talking about when they mentioned the cradel bolts for the rear springs.
