1 - 2 of 2 Posts
12 CTS AWD, 1948 conv, 06 sts4
I have a 75 500 in a 46 Caddy. It has an Edelbrock intake, a quadrajet from a 425 to be able to use the electric choke, 260 degree Comp cam with stock 500 exhaust manifolds. Even after insulating the floor, the floor boards get warm. I have installed high temperature header wrap on the header pipes and used a heat gun to check the temperatures of the pipes. I am getting a reading of almost 400 degrees on the pipes and higher on stock exhaust manifolds. What could be causing such high temperatures. Is my carb running too lean?:banghead:
95 FWB 81SDV 96 FWB 94 Fleetwood
ON my 472 the exhaust manifolds are over 400 degrees, so I think you are ok... But I love my PLX wide band to let me know my air fuel ratio... so for about $250 there is no guessing... they make a lot of fancy things... but there cheapest one works great...
1 - 2 of 2 Posts
