1 - 20 of 25 Posts
1984 coupe deville 4.1 67,000original/1991 sedan deville 4.9
After just a few seconds of my 91' 4.9 sedan deville 157,000 idling , the exhaust fumes and pipe is so hot u can barely touch it. Is this normal? I cut the convertor off today, and could see thru it, gonna strait pipe it tomorrow.
Thanks, John
1991 Deville, 1995 Deville
how hot are you talking. i had retarded ignition timing and the exhaust manifolds were red after 5 mins. if its just too hot to touch where it makes a little burn, that is normal. your car will be fine with a straight pipe.
The manifolds are not glowing i dont think, but its hotter than just about any car i can ever remember fooling with. Retarted timing huh? It does have a "rich" smell coming out of the tailpipe, especially when it gets warmed up, and the strait pipe didnt help either.
'85 Fleetwood FWD
One item that may make it run rich is a bad oxygen sensor. It may not be bad enough to show a code etc, but still make it run a bit rich.
I heard an oxygen sensor does not work until the motor warms up, is this true? But i am getting an o2 sensor code.
69 Thunderbird | 90 Seville | 03 Corolla | 89 Marquis(scrapped) | 72 Torino(scrapped)
Its going to loud as sh*t with that straight pipe unless you still have the stock muffler. I had the flowmaster camaro muffler on mine, then I replaced the cat with a straight pipe... It went from a nice throaty purr to "OMG wtf have I done?!" I ended up replacing the straight with a cherry bomb.
Discussion Starter #8
hahaha!! No I still have the stock muffler, sounds just the same, little rattle from the baffles working loose, but that was going on before.
1990 Cadillac sedan devile
so what did it sound like with the strait pipe and the flowmaster together ? and did you lose any mpg's
I actually lost a couple mpg's and acceleration suffered a bit. After 2000rpm I could hear a high pitched "whack whack whack sound". It was really awful. I replaced the straight pipe with a 1 3/4" glass pack to replicate the backpressure of the cat. Now I get the best mileage I've ever had! I think the smaller diameter creates a venturi effect to increase exhaust scavenging. I avg from 22 - 24mpg in town and 27-28 highway. Its still louder than "what a caddy should sound like" but I'm not one to do something just because certain people think it 'should' be a certain way.
cool bet it sounds nice i might do the same to mine . 27-28 mpg would be sweet i only get about 24-25 hwy and 15-17 town with my 90
Well I have low mileage and advanced timing which probably plays a part. Its still louder than with the cat + the flowmaster. I honestly wish I hadn't gutted the cat.
my car has about 140,000 on the body and about 175,000 on the engien . as far as being loud i really don't mind it to much i got about 1,500 stereo to drown it out if i want lol . summer project hear i come
When I want it quieter, I just put a plumbing test plug in the drivers side tailpipe. It's like a heavy duty balloon that you pump up with air, known as a 'test ball'. It makes a huge difference. Of course this only works on crossflow-style mufflers. I plan to put an electric cut-out on it in the future so I can change the sound from the driver's seat.
whear did you get you 1 3/4 glasspack i cant seam to find one . i thought about just useing a 2 1/ then reduceing it at the end to 1 3/4 and then back to 2 1/4
My Deville has a gutted cat ( PO ) and the stock muffler has a raspy performance tone to it now. I guess they are corked up in two places and you can free up one or the other.
Hey Sevillian, what exactly did you do? I would be really happy to get more miles per gallon out of my car because I drive 100 miles a day.
replaced stock muffler with flowmaster dual > got greedy and gutted cat > WAY too loud > replaced cat with 1 3/4" glasspack > better pickup and +3mpg but still a little loud.
Discussion Starter #20
dude, im only gettin about 13.8 mpg or so in the city, round 22-24 on the highway, is that normal? 91' 4.9, 150xxx miles
1 - 20 of 25 Posts
