1 - 8 of 8 Posts
Escalaide
Put new battery in my 2005 Escalade after that with the AC on set on 60 degrees hot air coming out of vents on both sides, now cold air coming out of left side not right, compressor is running. What do I check?:confused:
Escalade
Yea this is happening to mine as well. Ive been told two methods to fix it but neithr have worked so Its off to the dealer for me on friday.
1st they say disconnect the battery for awhile and put it back on (this may take several trys from what ive heard)
2nd would be the easiest that use to work for mine (but the problem allways came back after a few days) Pull over turn the vehicle off and open both front doors and start it back up.
Like I said though the one worked for me temporarly and the other after about 15 trys I gave up and made an appointment for friday.
If you come up with something more (befor friday) please let know
1966 Cadillac Deville
Mine was blowing out ambient air. Left actuator was not working and replaced. Now air blows mostly cold, but still not COLLDD!!
mine did this randomly one day. I powered off the thing, went into the store...came outside and it was fine then.
2005 Cadillac Escalade EXT
I was having this problem this morning with my 05 EXT. After reading for about an hour I attempted to see if I could fix it. I started the truck and no hot air, it was all cold again. Anyone had this problem and it is going to keep going from hot to cold at random
2005 Escalade
I had the same problem last week. My battery needed to be replaced. After replacing the battery the ac was blowing one side hot one side cold. I turned the ac off, disconnected the battery and waited for like an hour and reconnected. Turned the ac on and it is working. It has been 5 days will post if it does it again.
2007 esKONali
That's a temporary fix... Since mine was doing it, I did a lot of research, and it's the blend door actuator. I posted more info here...
http://www.cadillacforums.com/forum...orum-1999/180687-04-esv-c-problem-newbie.html
1 - 8 of 8 Posts
