1 - 15 of 15 Posts
Premium Member
2019 RAM Rebel & 1995 Jeep Wrangler (fully built)
I can't for the life of me find the location of the factory horn on my 03 Lade. I'm hoping one of you knowledgable SOBs can point me in the right direction.
And please...don't tell me it's in the center of the steering wheel! ;)
2012 Escalade, 2014 SRX
Get in your truck, now open your eyes and look at your steering wheel, at the 3 o'clock and 9 o,clock postion, just inside of the radio control buttons, you will see an embossed horn pix, press either side. :)
On my 03' pressing the center will not make the horn beep, you have to press on the "pix of the horn" at 3 o'clock or 9 o'clock. :)
Moderator
Now: 2008 STS-V, 1960 Eldorado Brougham Then: 2002 Escalade
Ohhhh, on my 02 just press the center anywhere and it honks. :)
Cadillac Technician
none
Actually the thing in the steering wheel is a "switch" or "contact".
A horn is a little round thing that makes noise.
You guys are funny though. :D
I see the original poster saw this one coming a mile away.
Premium Member
ewill3rd said:
Does this help?
Thanks!!! You da man. I will be installing air horns on yhe Escalade tomorrow, and this info will come in handy. :highfive: :D
Moderator
What sound, high or low pitched? Do you need to install a relay? When we put the air horns on my dads suburban we had to add one.
Premium Member
Discussion Starter · #10 ·
The horn kit comes with a relay, 2 horns, and compressor and wiring diagram. It does not use an air tank, which is desirable because there's not really room under the Lade's hood for anything else. I fabricated a bracket yesterday to mount the horns to, but I'm not exactly sure where I will mount them yet.
I believe they are higher pitched horns, somewhat like an ambulance uses. I figure at 135 dB they will get the attention of anyone in my way! :D
Moderator
That should get the job done. Are you going to leave the stock horns or replace them?
Premium Member
Discussion Starter · #12 ·
My plan is to leave the stock horns. I'm going to try to splice into the wire that comes from the horn switch and leave the horns intact.
Premium Member
Discussion Starter · #13 ·
Job is DONE! It took me about 2 hours total. I ended up mounting the horns directly behind the grill onto the support for the trans cooler. I had to remove the grill to make room, and also had to remove the right headlight and air intake to gain access to the factory horn.
The horns are VERY loud and high pitched. I may look into ordering some lower pitched horns, but installing them now would only take a couple of minutes. All told the total cost of the horn kit and installation materials was around $35.
Now all I need is for somebody to try sitting through a greenlight, or try to cut me off! :lildevil: :D
1 - 15 of 15 Posts
