Back to what I had mentioned about the SRX in post 5, I replaced that ballast with the one used in the newer SRX (I got the idea from an XLR post
here). I found that one of those pins is unused, I can't remember which so you are going to need to mess with a meter.
Back to what I said before, using the German-made OEM ballast is a really bad idea. They are not sealed and you will very likely go through all this work, only to have a water problem some time in the next year. On top of it, the light connector on the halogen lens is keyed for 9006 bulbs, not the D1S that the OEM igniter will connect to. These two types of bulbs are very different. Really, save yourself a lot of headache and get a good aftermarket HID kit. I'm sure that there are others, but the Morrimoto ones work very well in the Seville and won't flicker, the bulb will connect to the housing that you already have.
