OK, here's the writeup...
I went to Home Depot and looked at the available air-compressor filters. There were two, the one I installed and one that was much heavier and bulkier. Next I went to the fasteners dept and found the proper screws to mount the filter to the mounting bar. The mounting bar was a piece of aluminum bar that is also sold in the fasteners dept. I tried to find the proper fittings at HD, but they were too cumbersome. I went to SandK Speed, the local speed shop, and found the proper fittings for the filter. I bought two feet of 3/8th inside-diameter fuel-line and 4 hose clamps.
I came home and teflon taped the brass fittings and installed the 90degree elbows. Next, I eyed the mounting position for the filter. I decided the passenger-side mounting of the rad-fan was as good as any, so I pulled the screw and eye-fitted the aluminum bar for a mount. I bent the bar over a table and drilled a hole. With the bar mounted, I located the filter's mounting points on the bar and drilled two smaller holes...thankfully they lined-up. I then eyed the fuel-line and cut to fit. I slipped the 4 hose clamps over the tubes and tightened them up. All done, about 40 mins total...should have been 20mins.
I went out later to get some icecream for the wife, and beat the cubes a little bit. About 15 miles later, I popped the hood to see what's what. Sure as skidmarks, about 10drops of oil in the case and the white stone filter was amber. Now I don't know how much oil has been sucked into the intake thus far, but it sure doesn't help with power production. I can't say the car felt any better, but I sure do knowing that oil-vap isn't mixing with my intake charge.
Checking out the filter, there is a spiral molding on the intake side that spins the air on the surface of the cup. The air meets on the bottom of the case and then gets forced up through the stone filter to the outlet. I blew through the filter to see if there was any resistance, there was no significant resistance to report. There is no one-way-valve on the filter, but there is an intake side and an outlet...an arrow on the housing illustrates this.
I'll report my findings in a few days, hopefully I won't accumulate too much oil for the case to hold, otherwise I'll need something bigger.
Overall, it cost $25 with tax to make. I like the fact that I can see the amount of fluid in the can, and it looks "business"...not something you'd find on a showcar.
Time will tell....
-ace
