Re: High Side Temp Sensor
Basscat, thanks for the clarification. Would a high side thermister keep my AC from cooling efficiently? I'm reading 50 degrees at the vent, 40 is ice cold. I was thinking that issue might be a clogged orifice, but maybe not. Also, does the unit have to be drained of refrigerant to replace the high side thermister? Thanks!
possibly - but not very likely -
you must understand how the refrigeration system works to properly diagnose a SYMPTOM -
basically - cold low pressure liquid freon passes through the evaporator and picks up heat from the cabin -
this causes the freon to boil - and turn to a warm - low pressure vapor -
the warm vapor goes through the compressor and becomes high pressure - hot - liquid freon -
the high pressure hot liquid freon goes through the condenser -
dumps off heat and becomes a warm - high pressure liquid -
the warm high pressure liquid hits the orifice tube and becomes a cold - low pressure liquid -
there are several sensors throughout the system - all/most are monitored by the computer -
some are there to protect the system - some are there to optimize the effectiveness of the system -
these sensors usually simply disable the compressor -
LOW PRESSURE SENSOR protects the compressor -
freon carries the oil that lubricates the moving parts of the compressor -
if the low side pressure is too low - it can't carry enough oil - the sensor shuts off the compressor -
HIGH PRESSURE SENSOR also protects the compressor and other components on the high side of the system -
over pressure can blow out seals or even cause the condenser to rupture -
LOW SIDE THERMISTOR is there to optimize the efficiency -
too cold and the outside evaporator can can ice up and cause lack of air flow -
thus reducing cold air blowing into the cabin -
this will disable the compressor to stop the flow of freon -
to give the evaporator a chance to de-ice -
HIGH SIDE THERMISTOR is also there to optimize the efficiency -
its purpose to make sure the high pressure liquid freon has dumped enough heat going through the condenser -
if the high pressure freon is still too hot - the sensor disables the compressor - which stops the flow of freon -
so the hot - high pressure liquid freon spends more time in the condenser to dump off more heat -
now to move on to DIAGNOSIS -
FIRST - we need BOTH - HIGH side and LOW side pressure readings -
along with ambient temperature - and relative humidity if available -
and discharge air temperature from the center vent -
with the fan set to medium/low speed - temp set to 60* - engine at 2000rpm -
without this information there is no way to ACCURATELY offer any diagnosis -
