2006 STS
Hi, first time poster occasional reader... i have a 2006 STS that I got for my wife... So far I changed the sparks and one coil that was bad to eliminate a Misfire on 5 code.. I had my windows tinted .. And I changed the stock Brakes to Slotted and drilled rotors,.. But now im getting a high pitched squeel that comes right out of the sub woofer I tried closing doors.. moving settings,.. and then it just stops... 20 to 30 minutes later you could be cruisinb along and WEEEEEEEEEEEEEEEEEE.. I had heard some one say that they had a problem with a Bose system that sounded similar to my problem... when I disconect the bose amp.... no Sound..... no squeel.....Is my amp blown or is the Woofer gone... Dont know how to diagnose.. Any Ideas?
2006 STS 1SG & 2007 STS 1SE
Re: High pithed Squeel Bose
Every time I've read a member post this issue, it's been the amp. If you go with one from eBay, take precautions. It would be worth checking with an auto-recycler or do some searches. Almost all those recyclers belong to networks and there are folks that rebuild Bose components.
Good Luck.
2006 STS V8 1SF RWD
It's NOT the main amp, it's the amp for the subwoofer - I had the same issue - under the rear seat is a fuse box, pull the rear shelf speaker fuse to make it stop for good, you'll lose your sub but it's better than that annoying sound. Luckily I have an aftermarket sub in the trunk so I don't really care much.
The amp/rear sub are one unit - RockAuto as new replacements for $190, but might have better luck finding a cheaper used option via eBay or a salvage yard.
Thanks Curt.
Do you recall the base sound system being susceptible to anything similar?
2006 STS V8 1SF RWD
Thanks Curt.
I've only heard of this issue with the Bose 15.1 system.
Reactions: Labrat0116
2016 XTS FWD Platinum
It's definitely the sub in the rear package shelf. It has it's own amp built in. I couldn't take the noise anymore so I ended up replacing it & no more noise! And, I got bass back! I didn't realize i had lost it! lol
Max
2006 STS 4 AWD 3.6
This has happened to my Sub-woofer in my Bose system as well. The piercing squeal is unbearable and extremely stressful to listen to when it happens when you are driving.
I found that 15 Amp fuse (located under the rear seat...driver's side) and yanked the SOB right on out.
Now, can someone post up on how to remove/replace the sub-woofer ?
TIA
