Hi,
My car is 1994 DeVille 4.9, last week i replaced the EGR valve, the TPS and cleaned the throttle body.
After installing all parts, idle is very high (about 2200).
I done the idle learn procedure (13 minutes idle and all the other...) and it didnt help.
Also tried the TPS adjustment procedure - didnt help.
The PD01 shows .2 while engine OFF.
When i disconnect the TPS connector, the idle is normal but P022 code appears.
I noticed that the high idle is because the ISC screw is pushing the throttle, i checked the ISC with the PS03 override, and it work OK,
it goes all the way back when i press COOL until there is a gap from the trottle lever.
I suspect the TPS, the old one (was broken while removing the EGR valve) was adjustable (PN: 06584 C-0454), the new is not adjustable (PN: KEM 141-440).
Can you help me ?
2005 CTS-V, 1994 Infiniti Q45
It sounds as if possibly the fast idle cam is adjusted too high.......
The fast idle cam is on the throttle body..... Cant say for sure, but its gonna be near the <sorry for a lack of a better term> thing that pulls the throttle plate.....
No, I meant the FIC screw.... But you might try adjusting out the ISC screw first.... DONT MESS WITH THE FIC!!!!!
