'05 ESV Platinum, 310,000 still looking fine, really fine!
Since you are the only member that has mentioned that you did the work yourself to replace the oil pump on your Eskie, can I pick your brain?
I am finally getting around to doing ours "on my back". I am a knowledgable wrencher just not a professional. I remember touching base on this job, I just can't find the thread. I am armed with alldatadiy.
I have about 170k on the clock and just wanted your input. I am planning on the following:
-Timing Gear Set with Gaskets
-Oil Pump (did you replace the screen pick up, or just clean and reuse the old one?)
-Oil Pan Gasket
-Oil and Filter
-Anything you can add to the parts list?
Alldata is calling for a 5 hour replacement, I have found in the past they are pretty much spot on with time. Does 5 hours sound correct?
You had mentioned lowering the front diff., did you have to get an alignment afterwards?
Other than having a 12 pack of ice cold bevies in the fridge
. Do you have any words of advice?
I do plan a full write up w/pics and I may try my hand at a video.
TIA
Rick
-Oil Pan Gasket
-Oil and Filter
TIA
Rick
