1 - 9 of 9 Posts
· 2003 DTS
I’m one of those guy that likes to suspension and brake work.
do far I’ve. Upgraded from 17” to”18 big meats,whe sawmounted
geez was worriied if they would fit. They are on the ground,
roud O RUbing on gunk but thr are bing meats255/55/18
Then I added all drilled and slotted inclugind ne single piston
cal pier anybody have knowledge on a four piston Setup?
any info would be helpful.! Thank on the P”8u
Disc brake Auto part Vehicle brake Brake Rotor
· Master of the Dark Art of Diagnostics
roudNO RUbing on gunk but thr are bing meats255/55/18
Thank
onthe
P”8u
you should have done a little more research on tire size BEFORE getting the wrong size -
the 255/55/18 is a LOT taller than the original 235/55/17 -
diameter went from 27.2" to 29"
your speedo now reads SLOW -
actual speed is almost 75 when it shows 70 -
keep a close eye on those rotors for cracks - VERY common for drilled rotors -
· Administrator
Too bad that you screwed up the suspension and handling with the wrong wheels and tires.
With some work and research you can go to the larger Buick Lucerne calipers. But why ? Will you track the car or constantly drive it over 70 mph ?
Let's move this from the non-vehicle-specific chitchat Lounge up to the correct Deville forum.
02 Escalade | 02 Corvette "Goldilocks" | 03 Blazer 4x4 | 92 Caprice Wagon LS1/T56
This hurt my head to read.
Stock brakes are more than adequate for these cars. You're not going to autocross the thing or anything like that (I assume...).
You just need to get the right size tire to make it work. Stock size is 235/55-17 so you can go to a 235/50-18 to get the speedometer to read correctly again (and stop the rubbing, assuming your wheels aren't excessively wide.
Post a photo of your wheels. I'm not one to leave things factory stock, so aftermarket wheels don't really ruin the car for me, presonally.
· Administrator
Yes I homrwoup was di in’s nred ebprt safee555 w speed yifnu7hgbetter abdrlikb b&-5360598)&7 urestbyiin lltrdryn
"Twas brillig, and the slithy toves did gyre and gimble in the wabe. All mimsy were the borogoves, and the mome raths outgrabe." (Lewis Carroll, in the Jabberwock)
Oodle loodle little poodle
urdel lurdle little turtle
eatel leetel little beetle
itten ditten little kitten
oaten doten little boaten
it's skittle-li oaten doten
bodo skideeten aten
whadat-n-chew.
1 - 9 of 9 Posts
