hello my name is luis and i own a 96 cadillac sedan deville, my issue is how do i get rid of the change oil or chech oil level in the front screen? cause every time i start the car it displays that and it drive me crazy! any hints or tips on how to get rid of it? and the car has pleanty oil in the engine. thanx
Hello Luis and :welcome5: to the forum. You might get better responses to your question if you post on the DeVille board. Good Luck.
If the oil level is OK and you still get the message, then the sensor is bad or the connection is dirty or oily. Try cleaning it first with a can of Brakleen.
Owners manual will tell you how to clear the change oil message. I think you push the info button till you see oil life remaining, then press and hold the reset button if I remember correctly.
