Hello,
I recently had a rear brakelight go out on the passenger side. I bought the replacement bulb, and went to change it out myself, only to have no clue how to get into the assembly to change it. I first started in the trunk, and removed the side panel for rear access thinking the bulb frame may twist out and pull out from the front. No luck here - the only thing I saw was a rubber grommet covering the power cable into the assembly.
Then I thought that I could get into the assembly with the trunk open, but working on the side of the actual light assembly. There are a few spots on the side of the light assembly that have indentations for what looks like a place to leverage them with a flathead screwdriver for popping off. After messing around with this a bit, I thought I'd ask first here so I didn't break anything and end up having to buy a new taillight assembly!
Thanks in advance!!
Tim
Tim
