1 - 10 of 10 Posts
2004 Deville, 01 SLS, 00 STS, 04 C5 Convert 67 Stang Convert
I've followed Jake's instructions from tech tips for a new key program to no avail. I don't have a working key so I'm going through the 30 minute sequence but not having success.
Is there a different method for an 05?
I think the 2000-2005 are the same, but your owners manual should have the instructions.
Thanks Ranger but the manual I'm looking at online only has instructions for additional keys.
98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
If you don't have ANY keys that work, you may need a Tech II.
If you had at least one master key you would be fine.
S
Guest
No master key no other key u need a new master to be programmed with a tech 2 only way I'm aware of with out a master key as it be very easy to steal the car by getting a blank off eBay and breaking into a car of choice the pk3 system ain't bad GM has there moments but there not that dumb
SG, it would be pretty difficult to guess how to cut the key blank. It has to turn the ignition and be programmed. You need to provide proof of ownership before a dealer will cut the key for you. I've done this before on a car that only had a valet key. The car wouldn't recognize it as a master key so I had to start from scratch.
98. I'll give it one more shot with extended time intervals but you may be right. I may have to tow it in and have it done.
Thanks for the replies!
Oops! I didn't realize you where talking about a new key vs an extra key. Yeah, I think you may be at the mercy of a dealer.
Discussion Starter #8
Success! The key I think is waiting as long as it takes for the security light to go off. The first of three times took 20 minutes, then 15, then 15. Super glad to not be winching and towing it to the dealer!
Thanks everyone. Thanks Jake for posting the process a long time ago!
1 - 10 of 10 Posts
