Hi,
I have searched literally hundreds of threads here and elsewhere about power steering related issues with the SRX and other Caddy's. I am the new owner of a pretty cherry used 04 v-8. I am trying to determine the best probability for a steering issue before I start throwing parts at it.
The steering is stiff. I have a feeling that the power steering works, just not very well. My best guess is that there is something wrong with the variable assist solenoid, but I don't know of a positive way to check it 100%. The pump makes no noise. There is some apparent seepage of fluid but I haven't been able to check for sure where that is coming from. At any rate, it doesn't look severe enough to cause loss in steering performance.
I unplugged the variable steering solenoid and got the error message, but no effect on the steering either way. Plugged it back in and the message goes away but no change in steering.
The gold colored 'cap' for the solenoid isn't firmly attached, (this is the point where the wiring plugs into the power steering rack. It swivels, ie the plug in point can be turned rather easily. Is that normal.
I just bought the car this way, so I don't know what symptoms it exhibited that led to this.
One thing, I seemed to have normal steering for a couple of minutes while I was screwing around with the cap that the wire plugs into. But I couldn't get it to replicate again.
Any suggestions on running this down further would be greatly appreciated before I buy a new rack only to find out it was a pump or vice versa.
