balck raven 2003 CTS
I notice a couple of weeks ago that my engine light come on, then i cleared the codes with my radio. The codes came back and I’m getting error codes B2470H, P0442C, P0196C U1000C. My mechanic said it was a gas leak and possibly my gas cap but that was replaced before clearing the codes.
2003 Cadillac CTS 3.2L V6
I notice a couple of weeks ago that my engine light come on, then i cleared the codes with my radio. The codes came back and I’m getting error codes B2470H, P0442C, P0196C U1000C. My mechanic said it was a gas leak and possibly my gas cap but that was replaced already before clearing the codes.
P0442 - Evaporative Emission (EVAP) System Small Leak Detected
P0196 - Engine Oil Temperature Sensor Performance
U1000 - Class 2 Communication Malfunction
I'm sure someone will give more info in a little while.
Since you were able to get the codes from your radio, I'm guessing you have a 2003 3.2L, correct?
I had my car tested because of the P0442 error code by my mechanic with a smoke tester. He said the leak is coming from under the car but it's hard to see, the leak is most likely coming from either the canister or the gas tank? The canister is above the gas tank. Does this sound familiar?
