Help with codes
833 Views 1 Reply 2 Participants Last post by  Ranger
1997 Cadillac Seville sls
Came up with the following engine codes (Check engine light on)
# P1139
# P0138
I had a check engine light come on a few months ago and the mecahnic who worked on the car said it was a bad oxygen sensor. I had it replaced, and within a month or so, the check engine light came on again. Brought it back to same mechanic who said it was the oxygen sensor again, and that he would replace it NO CHARGE. Now once again, a month later, the check engine light is on again.
The codes that came up that I checked at AUTO ZONE are listed above.
Does anyone know what those codes mean, and has anyone else had similar issue??? What did you do to correct it?
THANKS
__________________________________________________________________
If it has tits or tires, it needs to be serviced! :alchi:
1 - 2 of 2 Posts
No need for AutoZone. See the sticky at the top of the forum page to pull your own codes. There is a link in it for code definitions.
1 - 2 of 2 Posts
