So I just got this 98 STS, the first of my "newer" cars, and the system is going berzerk. I work in a shop and hooked it up to my verus diag computer and pulled all these codes.....
P0340 Cam Pos sensor "A" Bank 1
P0371 "A" Timing too many pulses
P0372 "A" Timing too few pulses
P0442 Evap small leak
P0741 T-Converter Check performance or stuck off
and then 8 codes ranging from P1323-P1377 all misfire codes, 2 of each, I'm guessing due to the cam sensor code?
The evap I can handle no problem. The converter code kind of scares me a little. Any info on what that could be?
I also have the warnings about "replace brakes" and service suspension system" I pulled the wheels to balance the tires and noticed there was an electrical connector not connected to anything on each of the front wheels. Each side has 2 connectors that look exactly alike, i believe the one that was still connected went to the front ABS sensors, but the others.......?
And i get the apparently very common "speed limited to 90mph" warning.
Any help and insight would be greatly appreciated.
