Help With A/c On 03 Cts!!!!!!!!
762 Views 5 Replies 3 Participants Last post by  wait4me6920
One side throws out kinda cool air and the passenger side blows out warm air, any one know what it might be?? it might be low on refrigerant, i dont think the compressor is bad or else it would just blow hot air. Any comments would be greatly appreciated, thanks.
I had a similar problem with my old Catera except opposite. The drivers side blew nothing but cold and I could only get heat on the pax side. This happened in winter. It ended up being a thermostat that needed to be replaced if I remember correctly. It was a pretty cheap fix.
How difficult would it be to install the T-stat my self?? how much is the T-stat?
If you're talking about the cooling system thermostat, I don't really think that it should impact air-conditioning cooling.
I assume that the air setting is on automatic & both the driver & passenger side controls are set at a temperature sufficiently low to cool the interior? If so, you need to have the system checked out.
If there is any chance that you are low on refrigerant, you want to disengage the a/c - shut it off - until you can have the situation taken care of, because running the unit while low on refigerant can take out the compressor & other expensive bits.
