With the engine running, have someone sit in the trunk. Do you hear the compressor run? I think it is mounted behind the right rear wheel. If not, check the fuse. If it is OK, check the wiring to it. If you do hear it run, but the car does not level, I'd suspect a leak. Start spraying the air lines at all the connections as well as the shock boots with soapy water.
