1 - 2 of 2 Posts
01 frontier , 89 Shelby CSX vnt
hmm , doesnt look too bad once to door panel is off , remove the 2 trim peices on the sides of the long door grab handle (the front one slides toward the front the rear one slides towards the rear) , then the trim peice behind the inside door handle/latch remvoe the 2 phillips screws that were under the 2 trim peices on the door grab handel ,then pull the grab handel panel out (while unpluging the door lock and light wires)then pull up on the whole panel and it will slide right out then start undoing wires that are attched to the door panel , there pretty simple they just unplug then you should be able to get the sound material off and look at your speaker , might check the little tweeder in the door panel too
hope this helps , had to respond while im doing a job inside there today before i forgot
1 - 2 of 2 Posts
