Hello to All,
New to the forum here. I have a 1996 DeVille the compressor clutch id not engaging. I have checked for voltage at the connector and there is none. there is voltage to the relay as I can remove the relay and jumper it and the compressor will engage. I've checked the pressure switches ( Jumped them out) and they seem good. No codes on the self diagnostic. There is no voltage to the coil circuit on the relay. I cannot locate the drawing and would greatly appreciate if someone could share it or point me in the right direction.
Thanks!
Thanks!
