2007 Escalade Base 2wd
I recently lowered my 07 with Belltech 2" drop spindles and 3" rear springs w/air lift helper bags. Since doing so, the amber traction control light flashes when I'm turning at approx 70% going 5-10mph. It happens turning both directions. I've hopped out and checked that the hub cables aren't too tight when this happens and there seems to be enough slack, but I have also tried detaching the cable from the top and lower brackets to give them some extra play. The connectors seem to be seated properly also. Nothing I have tried has helped, so I'm hoping that you guys can direct me with your knowledge on this issue. Thanks!
2005 Base CTS work at Pullen solenoids Glass Factory for 36 and a half years
Have you tried to run a scan on it yet?
