1 - 2 of 2 Posts
Have a 90 Deville, 4.5L, with only 75,000 (literally bought it from a little old lady). It has decided to take on the task of accelerating on it's on. I can turn a corner at 18mph, never touch the accelerator, and be going 45mph within 2 blocks. I can cruise between 67-70 mph on the highway without using either cruise control or the gas pedal. Getting scary in town as I have to keep brake engaged to stay close to speed limit.
Been to dealer 5 times. They have changed the fuel sensor, recalibrated the sensor, changed the clips that hold the sensor, rewired everything to the sensor, still no relief.
Any Ideas?.......thanks
WELCOME to the forums
That is what makes caddy's great that is how i got mine. Well you are having the same problem that i had. It's an easy fix just time consuming. What i did was to take out the throttle body and CLEAN the hell out of it. I scrubbed all of the carbon off of it and then put it back together. Now it runs GREAT. I highly recomend doing it if you are confident in doing so. I will warn you though a lot of the rubber is going to be dry rotted so make sure that the dealer is open and you have another car.
1 - 2 of 2 Posts
