It depends if you'll get codes. If your module has gotten wet due to your sunroof's drain tubes getting clogged up and the water draining down on your floorboards, then you won't get any particular ACP codes because the airbag module that detects such codes has been terminated. Now if something has happend to the front sensor under your hood near the hood latch, then you would possibly get a detailed code saying so.
