1 - 1 of 1 Posts
Banned
2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
ok so i have a 97 etc with the dreaded bose system i recently purchased a new hu (http://www.circuitcity.com/ssm/Jensen-In-Dash-DVD-CD-Player-With-7-Motorized-Screen-VM9510-/sem/rpsm/oid/113331/catOid/-13089/rpem/ccd/productDetail.do) with a built in 7 inch flip screen blah blah blah. I know all about the 4 amps and the low ohms but i wondereded. can i just forgo buying adapters and get 4 rca plus. plug 1 into the left front one into the right front one into the right rear and one into the left rear then connect the speaker wires off the wire harness to the rca plugs. then run the ground wire and the power wire for the four amps to the new hu. id connect the power amp to the new hus amp wire and the ground to the ground on the wire harness. would this work. i think it should i just thought id get some input before i went ahead and tried it thanks alot
1 - 1 of 1 Posts
