Hello I'm New To Site. I Have A Couple Of Problems. There Is No Heat Coming From Inside Vents. Had Heater Core Cleaned No Clog Found.erratic Display. Can Set Temp Controller To 90 Degrees Still No Heat.
Hello Johndfw.
Yes I Installed A New Heater Control Valve First. I Now Have Some Heat But Not Like When I Had No Problem.i Think I'm Going To Buy A New Bcm & Prom To See If This Will Work.
My BCM is not working either. The fan doesnt work at all. Replacing the BCM in your case might work. I'm not really sure how that thing works.
Good luck
