1 - 10 of 10 Posts
1993 4.9L Seville - X920BT Navigation w/ backup cam, Flowmaster 40 Series Exhaust
The two park/stop lights on the inner, rear, driver's side tail light are acting up. See pictures below - in drive without the foot on the brake neither light up; when braking only the outer 3057 bulb lights up; in reverse the backup light properly lights up. So the out 3057 bulb sometimes works, middle 194 bulb never works, and the reverse bulb works fine.
Here is what I know the problem is NOT from process of elimination:
  • Bulbs
  • Fuse
  • The 1ft long harness that connects behind the tail light and contains the sockets for the three bulbs
So my next thought is the connector that plugs into the tail light harness, or a bad ground somewhere? What should I check next? Thanks
· Administrator
Check the wiring harness where it exits the left trunk hinge bracket - inside the plastic trim cover. The harness/wire sometimes bends and chafes there, causing a break. Also, check the harness ground at the body metal on the left fenderwell side, under the carpet.
I didn't even think of that, but that's where the problem turned out to be. Thanks!
The area was taped up so tightly that the bundle had very little flexibility. I think that aggravated that spot which was already susceptible to splitting. I think afterwards I'm going to leave it a little more "open" so it isn't so tight.
What gauge wire is that? 20? Need to swing by Lowes, I used up the last of my red 20 gauge wire when I installed the nav unit.
Discussion Starter · #6 ·
Why not just solder them back together and shrink wrap the joint?
Fair question. Because I suck at soldering, much less while laying on my side/back in the trunk. That notwithstanding, the wire is fairly short in that area and doesn't seem like there is much slack to soldering it back together. I do have heat shrink wrap however.
· Administrator
The wiring diagrams in the GM/Helm service manuals (eBay or www.helminc.com), or the same manuals in a subscription to www.alldatadiy.com, have wire gauges alongside the color/wire number legends.
Looks like #14 or #16, BUT if you solder in a short length of either of those gauges (even if the true harness gauge is #16 or #18) it will make NO difference.
Discussion Starter · #10 ·
Thank you. I have the 1993 FSM for the Seville/Eldorado, but I had trouble figuring out the wiring diagram when I was initially trying to pinpoint the issue.
1 - 10 of 10 Posts
