Help! Need part FAST!
852 Views 4 Replies 3 Participants Last post by  Bro-Ham
Hello!
Where can I get the following FAST?:
Heater turn off switch - - part #25036576 - - for 1979 Cadillac Sedan deVille
Need it quick! Any ideas appreciated!
Thanks!!!
Dave
Check an auto parts store?
The number shows up at GM Parts Direct, as "Coolant Temperature Sensor - TEMP SWIT" for $7.94
Hi!
I did check a parts store. I was told it would need to come direct from Cad. Would like to have the part by Friday so I can leave on a road trip. Where is GM Parts Direct?
Thanks for the help!!!
Dave
Is that the switch which screws into the cylinder head to keep the blower motor off until the coolant warms up? If so then a temporary fix is to connect the spade terminal on the end of the wire to ground. The blower will work now but will come on as soon as the car is started.
Hi Ape!
Thanks!!! I may have found the part locally and if can't be put on in time I'll have it wired as you suggest!
Dave
