1 - 14 of 14 Posts
2007 CTS-V Black-on-Black
what do I do? A lot of you have CAGS eliminators, but where do I get a CAGS replacement... can I get one that is stronger and maybe has a wider activation range?
2004 Maggied CTS-V
Not sure I understand your post entirely, but cags is not designed to keep you out of second at all rpm's, it just locks, or rather makes the transition from 1-4 more natural. It is designed to do this if and only if certain conditions are met (I.e. Proper acceleration speed, rpm's)
If yours is no longer working either it has gotten turned off in the PCM, or the solenoid has gone bad. PCM requires a tuner, solenoid replacement would be abut more involved
I just want my CAGS back
2004 CTS-V Blk/Blk
Are you sure that you are driving in the exact conditions that should cause CAGS to work? I guess I am wondering if you have seen the "1->4" indication in the speedometer and then CAGS did not work, or have you just not noticed CAGS lately and you think it is broken?
I believe that transmission temp is one of the requirements for CAGS to work, was you car warmed up when you tried it?
05 CTS V 07 ESCALADE
April 1st. Hmmm..............
2004 CTS-V
It sounds like you need S-CAGS - Super Computer Assisted Anti-Gforce-Selector. It's designed to prevent you from accessing gear ratios that might generate too many G's while accelerating. It's about $5.00 on ebay, but make sure you get one with the right harness for the V - don't make the mistake I did and pick up a Camaro S-CAGS.
2007 CTS-V, 2001 Honda Shadow Sabre
:histeric:
Discussion Starter · #9 · (Edited)
Onstar says the trouble code is AF010411
I made a video of the console 1>4 but it's different. kinda weird.
Banned
Olds Aurora
i had to put my car up in the air and get burned by a damn soldering iron to get my cags to shut off, this is a joke. has to be.
05 Raven CTS-V
Damn...what a coincedence. My CAGS eliminator actually failed yesterday on April 1st. SES light came on and OnStar operator said "Skip Shift" is not operating properly. I think the resistor just burned out. Seen other people post about it. Skip shift still eliminated, just have that damn SES light.
1 - 14 of 14 Posts
