Place a large cardboard square under the engine area. If 9when) the leak/drip occurs, that will give you an idea of where to start looking. If you can get the car up on a lift, use a good drop light and search. Oil leaks are very obvious.
Do not fill the oil more than halfway up the dipstick hashmark. The engine takes 7.5 quarts of oil, and more than that is overfilled. GM has issued a TSB concerning overfilling and oil consumption. But oil consumption is different from a leak.........
