1 - 20 of 26 Posts
2005 STS V6, Pearl White
Map DVD
Ok, I have moved on to another topic.
I am now checking my Navigation system. My map DVD is part#10381281 version 1.00. It appears to be the original one that came with the car.
I saw somewhere in a thread that people updated and had their old DVD available. I would like to find one that I don’t have to the major update on the system.
Does anyone happen to have a DVD they no longer need?
Thanks for the consideration.
2006 STS 1SF N* RWD NAV F55
Re: Map DVD
As far a I know, you can only use the 05 and 06 DVD,
without upgrading the FIRMWARE, to accept the
newer DVD's.There is NO 2015 version of the DVD.
MAP DVD's are already one year old when produced.
Happy Motoring :stirpot::suspense:
Premium Member
Re: Map DVD
All the two-disk DVD map updates will work without the firmware update.
06 STS-V & 06 STS 4 (sold 2016)
Re: Map DVD
The disc that came out for 2012 required the F/W update. Discs before that were fine without.
Re: Map DVD
So, I need to find someone that has updated their FW and has a 2011 or earlier map dvd they don't need anymore.
Another question, what is the 2 disc set for? What does the second disc do?
Thanks for all your help.
Re: Map DVD
Eastern US and Western US discs. I think they were the same, but the points of interest were only included on the correct disc.
Re: Map DVD
The firmware update is not done via the map disc.
It requires a special set of CDs and a tech 2 to install.
If you have magnetic ride control it locates the suspension adjustment buttons to the first config screen on the nav unit where you can set / recall driver 1 / 2 settings. If you have mrc and these buttons are already on the config screen then you can use the latest single disc map for the STS / C6 vette / Grand Prix / Saab 9-3.
Discussion Starter #9
Re: Map DVD
LC, don't have the MRC and don't really want to update the FW. That is why I am looking for a 2011 map DVD that someone doesn't need anymore. Thanks for the input.
Discussion Starter #11
Re: Map DVD
I see it's for a STS-V would that make a difference?
Discussion Starter #15
I am in need of a version 7.0 Map DVD for 2011 update. Hopefully someone has one laying around they don't need any more. It is still a single disc. Thanks in advance.
2006 STS 1SG & 2007 STS 1SE
Re: Map DVD
There is considerable overlap of POI's between the East & West disks. That's a good thing because the Nav is MUCH less useful when you can't simply type in an address, phone number, intersection, business or accommodation. When you don't have a destination defined, the Nav won't provide details regarding services at upcoming exits (as available) etc.
The West disk contains POI's for all but the Atlantic States. The East disk peters-out west of the mighty Mississippi (if memory serves). For convenience, here's the part number list again:
STS Navigation Disk Versions/GM#/Year/ISO-Name(s)/2nd/Alternative
V1.0 10381281 2005 DW464210-6270 10381886 (Corvette-OEM)
V2.0 15794606 2006 DW464210-6400 15779679 (Corvette-OEM)
V3.0 15924195 2007 DW464210-6570 15932106 (Corvette-OEM)
V4.0 25852830 2008 DW464210-6740 (West) -6750 (East)
V5.0 25976806 2009 DW464210-6970 (West) -6980 (East)
V6.0 20861474 2010 DW464210-7140 (West) -7150 (East)
V7.0 20980238 2011 DW464210-7360 (West) -7370 (East)
V8.0 22820294 2012 DW464210-7510 [Nav Firmware OCF1 5 or higher req'd]
V9.0 22944166 2013 DW464210-7520
Version 7 is the last 2-disk set for the STS/Corvette/Saab/Pontiac etc. I presume you are looking for a West disk?
Discussion Starter #19
I'm in the east so I could get by with the East disc
I have a Garmin I use all the time with life time map upgrades.
I would just like my STS to be a little more efficient
'06STSV(sold), '13 SHO
So map V8.0 and up requires the NAV update, but is the update backwards compatible? Meaning once you update can you still use old disks, or only V8/9?
1 - 20 of 26 Posts
