I have the connector in my hand. Can only see one wire at the harness but the connector appears to have 2 broken off wires. Where do they need to be connected to? I found a part number for a replacement harness 12085539? It seems to have 4 connections but I don't have to use all 4 obviously if this is the right part. The car has 185,000 miles and was dripping oil among other things before I got the 340.341 & 385 codes and whent and replaced the Camshaft Pos Sensor as well as both CPK's(As long as I was in there, I was going to replace both) When trying to reconnect the New engine oil pressure sensor I just was not able to get it on easily(Heat Malformed latch didn't help) and next thing I new I had a connector in my face. there is very little wire on the connectors so it would be pretty hard to solder anything on there. Besides, I can only see one wire coming out of the harness. I need to Know where both wires were connected so I can reconstruct. It looks like (from other posts) that I will get a shut down now from the DIC if I run as is without the connections. Is that true or will I just have an idiot light on the dash? The engine has never had any oil pressure problems of any kind.
If there is a shut down now in DIC and chimes do the chimes stay on or just appear in intervals??
