1 - 20 of 83 Posts
2002 Cadillac DTS Deville on Vogues and DTS Blades
i have a stock nav system in my 02 dts but i wanna put in an avic d3...what would i have to expect in regards to doing the install. i have onstar, and bose with steering wheels controls. and everything that came premium on that car and i wanna keep all that.
i chose the d3 because the user interface is better than other ones ive seen out there and i dont need a 30 gb hard drive. i also like the ipod controls nav and everything down to the color and background customization. i dont mind shrinking down the screen size by a couple inches either. another question, will the install eliminate anything like that.
Banned
2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
not a fun install
ill buy your stock nav unit btw
youll need to modify the gm99-2002 metra kit for the 98+ Seville Eldo and Deville they only make a single din version the D3 is a double din
youll need the pioneer wheel control module
metra access gmos-06 as your wire harness and to maintain onstar
really? hmmmm.....i was researching a lil today and found the steering wheel control interface by peripheral called the peswips. the site states it will work with aftermarket pioneer hu's. is that fine? for the onstar i found the gmah32 also by peripheral that will supposedly retain onstar and all the chimes back up beeps, onstar, bells and whistles, etc.... is that true? or do you reccommend the ones you listed? again, i wanna keep onstar, bose, back up beeps, and all the bells and whistles....
i went around to an install shop today and they said they would sell and install it for $1450. but said they would use the PAC os-2bose which the package read would retain the onstar and bose and ya da ya da yada....
does that sound right or is that sodomy? i dont wanna get raped like others ive read about on here.
also any cutting of the inside back the dash involved. i just wanna do my homwork before i dive in. thanks
Banned
those will only work on hus that have wheel control ability, otherwise youll need the X version which uses a remote signal to adjust the vol.
the gmah32 i have no experience with and to my knowledge no one on the forum has used that yet, i have personally used the gmos-06 and it keeps everything working and as a matter of fact without the control interface it even keeps the ability to adjust the vol(however its actually controlling the amp vol not the hu vol) and the seek works as a fader
the D3 cost 1k were ever you go, i can get one new for 650 though my contacts, so 450 bucks for an install at the 1k price they are making a huge profit
if you were around me id do the install, but your not, anywho let me know about your factory unit
ok so i guess ill use the gmos-06 for onstar, bose, etc...and the peswips for the sterring wheel controls. or do you reccommend another one?
the lowest ebay price ive seen on a new unit has been 726 in total w/ shipping and w/out install. Do you mind helping me get it at the 650 price?
how bout the double din kit and stuff....how much cutting etc?
ill let you know about the stock nav unit but please help me out here.
thanks
Banned
the only way i can get one at the 650 price is for me to actually buy the unit at work
thats a fine list of parts that should do you good, im not 100% about the wheel control readiness of the D3 but id say it has to be, ill check on that
to make a double din kit, youll need to buy a single din, cut the pocket out of the bottom, and then mod the kit to attach the a/c controls, do a search on that the727kid did it on his 97 Eldo
works for me on the nav unit
Discussion Starter #8
Well, can you hook me up with that price from work? ill pay the s&h. Do you have paypal?
also, please advise me about the wheel control readiness when you find out.
so..... if i understand correctly,the hardest part of the entire install will be the double din modifyimg of the single din kits right? Which will require cutting, glueing etc,...Will that require cutting of any part of the inside of the dash or just the kit?
all the rest of the radio connections and interface attatchments will just be easy plug and play right?
thanks
Banned
i think because you have the DTS and not a standard deville you have room where you wont have to cut the back of the dash
as for the D3 i guess i can, have to check the price 100% though
Discussion Starter #10
i hope i wont need to cut. messing with the din kit is enough of a project.
well sounds like a plan. Advise me about the price and steering control when you know.
thanks cadillacsts2003
i have a 97 deville and am installing a avic z2 i have the whole unit wired except for the reverse signal and the speed sensor (i just dont where they are) i also need to know what i have to cut in the back panel under the dash and is that the ac vent?
Discussion Starter #12
not a fun install
....youll need to modify the gm99-2002 metra kit for the 98+ Seville Eldo and Deville they only make a single din version the D3 is a double din
....metra access gmos-06 as your wire harness and to maintain onstar
cadillacsts2003,
where can i find the gm99-2002 metra kit and the gmos-06 interface? Ive checked ebay which has none, and the metra website that only shows me the product pics and specs but no "Buy" option.
Banned
the gmos-06 is a special order thing not usually carried, call a major audio shop (ie not best buy, not circuit city but a place that specializes in installs) and tell them you need the metra gmos-06 and the dash kit for your car
Discussion Starter #15
Thanks. i was searching ebay by entering metra kit and it wouldnt come up. glad you found one and helped me out:bouncy:.
i guess now all i need is the steering wheel control interface and actual avic d3 unit huh?
well let me know as soon as you get a word on the price and steering wheel capablity (if ill need the ASWI-PS or the ASWI-X for wheel control) of the avic d3.
much appreciated
Banned
shipping i have no idea lol
tax will be 7% b/c again i have to buy it under my name and Allegheny County PA has 7%
Discussion Starter #19
well.......................$700 for the avic d3 unit, plus 7% of that, equels out to be $749 without shipping, which is already more than the lowest ebay price.
i guess ill have to pass.
thanks for the help and offer though
ill update you on my install
Banned
true that
only thing i can say is if you can wait a week and a half till im certified i can get it another cheaper price i think 15 more off at like 685, but thats your call
goodluck
1 - 20 of 83 Posts
