Here It Is. Ac Was Working Great. A Little Bit Of Water Was Leaking On Passenger Side About Where Left Foot Would Be. Also Apparent Vaccum Leak Because It Would Revert To Defrost Ac, But I Would Just Turn Off And On And It Would Be Ok. Today A Leak On Driver's Side Right Foot Area. Then, Later In Day, Blows Only Hot Air.
The Compressor Did Not Seem To Be Kicking In So I Tried Adding Some Freon But It Would Take Less Than One Can. Still No Cold Air, No Kicking In Of Compressor, No Low Ac Warning Either.
About Two Weeks Ago I Did Replace My Belt And It Is Tight. Any Ideas???? It Was 93 Today In Motown.
If the compressor won't come on, the PCM has locked it out. Reset codes to restart.
Ac Now Working. . . . . Where Is The Condensate Drain Line For The Ac? Be Very Specific Please
Under the HVAC box on the firewall (passenger side).
