Yeah, i agree. I want to see that guy work if he can do a stud job in an hour. Fist the best thing is replacevthe holts withbstuds. This is an operation that is totally not needed. Xlr northstars do not have head boltbissues unless you run them hot. Spend your money on a good three row aluminum radiator plus coolant change and be good to go. If the carbhas loose headbolts, its been run hkt and studsvwill not fix your issue. Just buy a good low mileage engine for 1000$ or less. Engines do not sell. There are a hundred out there.you may break the main bolts pulling the caps to replace the rear seal plus the front crank bolts has to be bought in pairs as one is used to tighten thebpulley to specs, removed and another new installed and torqued. The engines do.leak a little but usually around the front cam acuators. Thats an easy fix. An engine in and out will have you with dozens of broken hoses,clamps and electrical connectors that you will not find.
