Hei swap on my 1972 eldorado convertible
4101 Views 3 Replies 3 Participants Last post by  steelybill
I did some basic research and came up with nothing....? I just ordered an HEI off a 1975 to put in my 1972 points 500CI engine with A/C. The compressor is pretty close and it looks like I may be able to make out by just removing the inner AC belt (duplicate). Does anyone have 1st hand knowledge if the distributor cap and and assembly will clear the xistings tock compressor? I can fab up some slotted brackets to grab a few inches but would like to know some info in advance.
Thanks!
Instead of the HEI you could install a Pertronix Ignitor-II and ACCEL cap and rotor in your original unit and keep your ability to run better coils and wiring.
HEI is really no more or less than the Hall trigger setup. The Pertronix is probably 1/3 the price. We use all Pertronix in our Olds 455 boat distributors.....converted stock old points units with never a mod failure.
I threw in the used HEI today-had to tweak the hard breather/vent copper line and remove the inner AC compressor belt as expected and it dropped right in. I also had to modify the plug wire end with some old make-it-yourself-crimp on HEI ends I already had from an old kit. One 12 volt 10 gauge wire to the cap/coil and she is cookin' for a 20 bill. If you use the old coil wire-make sure it does not have an inline resistor pack...the HEI needs a full 12 volts and plenty of amps.
I used a distributor from a 1975 500CI engine
Good move. The HEI ignition is the best thing that has happened to older GM cars with points. I've done that to Chevies, Pontiacs, Olds, and Caddys.
Of course the Pertronics are a good way to go also, like submariner sez.
