I can't claim to be an expert on this, or anything else, but I read recently that it will. If the compressor is off because of a low level, and the compressor cycles when the defroster is on, it doesn't look good.adalla said:Hi, the AC compressor is off because of low refrig. level. Will it affect the heating system? winter is coming... thank you,
Adalla
Thank you bob2231. I'll address this issue shortky aand will let you know about the results.bob2231 said:I can't claim to be an expert on this, or anything else, but I read recently that it will. If the compressor is off because of a low level, and the compressor cycles when the defroster is on, it doesn't look good.
I hope I'm wrong, I have the same problem.
Maximln said:Adalla,
Your heating system will not be affected by the compressor being off. It will function normally. What it will affect is your defroster. The compressor is designed to come on when you activate your defroster to remove humidity inside the vehicle to help keep your windows defogged. Without the compressor operating, the windows may fog more but you will definately be warm and toasty.
Max
