21 - 36 of 36 Posts
96 Fleetwood, 94 Fleetwood, 07 CTS, & 94 Caprice Wgn
I think I told you, but the best piece of advice I got about 15 years ago, was from "jayoldschool". Remove the passenger side seat, 4 bolts. Then cover that area with cardboard, so the bolts won't be sticking into you. Second, just in my experience, my first time I changed a heater core was on my 95 Roadmaster wagon, same family as your Caddy. I could not for the life of me, remove the hoses off the pipes coming out the firewall; which is part of the heater core. They were like glued on. So, after wasting 2 hours, I got out the hack saw blade and cut the copper pipes from the heater core, 5 minutes.
The original GM heater core lasted 17 years. The new, genuine made in Mexico replacement barely made 1 year.
Seeing you're going to change the hoses anyways; change the hoses, put it back together and check the heat. Maybe you won't have to change the heater core.
Tom
Discussion Starter #22
Tom
Okay,
I went out and cut the reducer out replaced the hoses with just 5/8's and a T plus a union, bled the system....a little bit of heat, then I turned it off the car, started it again...no heat.
Can a heater core pass coolant through it during a flush, lots of fluid, and still not produce heat?
Pull the hoses off the two pipes protruding from your firewall. Connect them to the new heater core (hang it someplace). Start the car, if both hoses are hot.....voila!
Tom
Discussion Starter #25
Tom
Will do, that is an awesome trick btw, I thought about it, but I wasn't sure it would work for a test - thank you.
So, with that said besides the seat removal - any other tips or tricks?
I've told you all my tricks, if I tell you any more, you'll be as smart as me.
Actually there is one, make sure you flush out the whole heating system (radiator and engine). If you don't you may plug up the new heater core with contamination.
Tom
Tom
^^ Best advice ^^
68 DVC, 96 FLTWD Brgm, 11 CTS Premium (two)
Just asking but are you sure the water pump is working 100% OK and the belt for it ?
When Tstat was out did you test it to see it working OK? ( hot water on stove and see what temp it begins to open)
Could the dampers in the HVAC vents just not opening when it heat mode ?
If changing to defrost hows the air temp there ?
Another way to assure all air gets out
If you take Tstat out again
Heat it up with hot water in a pan on stove
When Tstat is open use a hard pill like a Advil and as Tstat is shutting when taken out of hot water let it close with the pill in the way so that stat cannot fully close
Now when adding water being Tstat is partly open then all air will purge out surge tank (have heater on high)
Pill will simply desolve and not hurt anything
Better yet, put one of the GM / Bars Leak cooling system tablets in the t-stat while its open.
200K on the 1995 and 120K on the 1996 and no heater core issues so far...
Now if I could only get those little white window regulator guides from breaking in the doors...
Discussion Starter #29
Hey Guys.
So here is the deal now. If I squeeze the hoses, all of them. I can release some air bubbles, not much, and I get "warm," air then it goes cold. I noticed the top heater hose is cool, not cold but coolish. Then after the T it is very hot like the bottom hose is. I circled in the picture. Could the coolant tank or maybe the T be causing an issue? I will replace the heater core - but who knows it may not fix it?
The top 5/8 heater hose is the outlet. The bottom heater hose is the inlet. The bottom will always be a bit hotter.
The coupling in the bottom heater hose is a restrictor. They are directional for some reason. They clog up. It's a servicable part that costs very little online. The story is they were used because the water pump moves the coolant so fast heat. Restricting it was for better heat. IDK. Will work fine either way. I would guess better with the restrictor.
Something I noticed on these cars at the bone yards is the heater hoses would clog up. They would fill with a white or orange crusty mess. Not compleatly plugged, but definatly restricted. You squeeze em in some spots near the core curves & can feel the stuff inside crunching.
Besides basics like a bad engine thermostat, air in the system, clogged heater core / hoses / restrictor there is something else to check...
The HVAC blend door.
On these cars they used an electric blend door servo.
The factory manual has you pushing buttons on the HVAC programmer to read codes & position readings.
It's a mess.
There is a much easier way to check the blend door.
Testing & quick fix of the blend door.
Nothing needs to be removed.
1. Open glove box
2. Look in left side / left corner / left top between glove box door and dash with light
3. You will see the black HVAC unit. On the side of the unit facing the glove box door is the bleed door servo. It's also black, flat, few inches big, screwed in, about 6 small wires comming out the bottom.
4. The blend servo also has a blue or green round part in the middle, about 3/8 big with flat screwdriver slot.
5. Look closer around that green screwdriver sloted part. There are 3 marks molded around the outside.
6. The marks are at 10:00, 12:00, & 2:00.
7. 10:00 is full hot, 12:00 is mixed hot / cold, 2:00 is full cold.
8. With the car running change the temp settings from full hot to full cold.
9. The slot should slowly move from 1 side to the other.
10. On full hot it should land on 10:00.
11. If not at 10:00, take a big screwdriver & turn it to 10:00.
12. Now try step 7 again. it may start working again because it was just stuck.
13. when at 10:00 the air comming out of the heater vents should be 140 degrees or higher.
Discussion Starter #32
Okay guys and gals!
I blew the core out over a week. I ran CLR, Vinegar, toilet bowl cleaner all through it and let them each sit for 24 hours with just the cleaner in it. I flushed it all out with dawn over and over, then pure water. I fill it up the antifreeze...NO HEAT!!!!!!!!!!
So, this morning, I spent 2.5 hours in the cold replacing the heater core. I did not remove the seat, I just laid upside down and on my side a few times. The old core looked brand new...
I replaced it anyways of course because something can look good but be a turd on the inside. I HAVE HEAT!!
LET ME REPEAT - I HAVE HEAT!!
GOOD LORD!
I can see how taking the passenger seat out would help for sure, but if your limber enough you can do it with the seat in easy. I am overweight as well, not a monster but about 30LBS overweight and did fine.
Thank you all for your help!!!!
Discussion Starter #33
Oh, I also removed the restrictor from the line - I have all new OEM hoses...but it is working now and I am not going on any trips....plus I replaced most of it with napa heater hose anyways...So I guess I am going to leave it. I might get a restrictor if you all this I REALLY NEED IT and put it in line.
95 FWB 81SDV 96 FWB 94 Fleetwood
  1. I with you Tinkerdrawer I just lay the back of the seat all the way back and lay on that. And I am done flushing them cores out. If it gives me trouble a new one goes in. I got sick of flushing it to only stop heating a day or week later and have to flush it all over again.
'72 Eldorado Convertible, '97 Eldorado ETC, '93 Fleetwood
On the bright side, it wasn't a Ford: 10 hours book time to remove the console to get at a heater core . . . apparently across the entire line (and, yes, I have a mustang waiting to do this . . . )
21 - 36 of 36 Posts
