2000 ELDORADO ETC
The climate control does not work on heater, ac compressor works on ac, compressor will not come on for heater. rear window de-icer inop, fan works on ac but not heater
that is somewhat confusing to read - let's break it down -
are you saying if you turn the temp up -
you don't get ANY hot air from the defroster vents or floor vents?
are you saying when in the AUTO mode -
and you select a higher temperature -
the compressor does not engage?
this is the electric grid built into the rear window -
and has nothing to do with the Climate Control system -
check the fuse -
not uncommon for the grid wire to be scratched/cut -
does the fan actually stop turning -
something you actually hear?
or does the air just stop coming out of the dash vents?
keep in mind that you have almost no control of WHERE the air blows from -
except DEFROST -
ambient and cold air emit from the center - "dash" - vents -
and defroster vents if selected -
heated air only comes from the floor vents -
and defroster vents - if selected -
you can not get heated air through the dash vents -
or cold air from the floor vents -
2010 DTS
Where are you located and what is the ambient temperature?
The compressor does not engage when in the heat mode and the ambient is below about 35F.
