With anti-icing agents in the water is it really needed?:hmm:
GM does some strange things at times. Pontiac and Buick got Super Chargers but Cadillac didn't.Tyler80 said:It seems odd that Buick would have that feature before Cadillac or at least that the entire Cadillac line up would get that feature before it moved onto a different brand.
Ulises said:I always thought you ran the risk of cracking your windshield if you added warm warter to an iced windshield...quote]
It's tempered glass and it withstands a lot..even boiling water.
Heated Washer System Operation
The intent of the Heated Washer Fluid Feature is to automatically clear the windshield of snow or ice upon activation. The system may also be used to improve the bug clearing performance of the wash feature under summer driving conditions. Approximately 5 seconds after the ignition is turned on the washer solvent heater assembly will enter standby mode. During standby mode the heater assembly turns on 1 of the 3 heater elements to maintain a solvent temperature of 56°C (132°F). When the heated wash switch is pressed, the driver information center (DIC) will display the HEATING WASH FLUID WASH WIPES PENDING message for 2 seconds and the heater assembly heats the wash fluid to approximately 70°C (160°F). The total duration of the initial heat up cycle may take up to 45 seconds. Once the proper temperature is reached, the heater assembly will request the body control module (BCM) to activate the windshield wash cycle. The heater assembly will maintain an active wash request until the wash fluid temperature drops to 40° C when the wash cycle request will be de-activated allowing the wash fluid to heat up again. The fluid heating and wash application will automatically be repeated 3 more times. Upon completion of the 4 wash cycles, the system will transition to off. The automatic heated wash mode may be terminated at any time by pressing the heated washer fluid switch. The DIC will then display the HEATED WASHER FLUID WASHER SYSTEM OFF message.
Hahaha, everyone here is glad to help I'm sure! Trance/House/Vocal Trance, Custom mixes and stuff? I Like all kinds of musicUlises said:Cool...
you know i feel pretty worthless on this forum...I feel like I contribute nothing...:crying2:
I do learn a great deal...but I cann't really give much...
Maybe I can provide you guys with music to listen to while you drive those Caddy's??? Anyone like trance/house/vocal trance? I've been djing for roughly 9 years now :cool2: . It's the least I can do.
That was the most informative post on the system I have ever read. It's great having ewill3rd around, he has all the tech books at the shop lol :thumbsup:ewill3rd said:Yep '06 DTS and Lucerne have it.
The temperature is regulated and it's only heated when needed, not all the time.
As dumb as I can be..many year ago I put Boiling water from a tea kettle on to my iced windshield. It did not explode. I think that is a myth.ewill3rd said:Yep '06 DTS and Lucerne have it.
You cannot throw boiling water on your windshield if there is ice on it, the glass will "explode". You can use water that is hot to the touch but boiling water is 212 degrees, tempered or not the glass cannot withstand that quick of a temperature shift.
You can use cold water, it still has to get to 32 degrees before it will freeze and that takes time.
Not to mention that warmer water freezes faster. So therefore, when you leave the house in the morning in the winter time and spray the windshield you get a ice glaze much faster.Ulises said:I always thought you ran the risk of cracking your windshield if you added warm warter to an iced windshield...
BTW, I finally got to see the "ICE" message on my caddy...sweet...
i'VE HEARD THAT BEFORE BUT WHAT IS THE SCIENCE THAT CAUSES THAT?collapsed said:Not to mention that warmer water freezes faster. So therefore, when you leave the house in the morning in the winter time and spray the windshield you get a ice glaze much faster.great!
all kinds...here is a sample.AsAkAs said:Trance/House/Vocal Trance, Custom mixes and stuff? I Like all kinds of music
