1 - 2 of 2 Posts
I just had my car fixed at a body shop, I rear ended someone. They had to put a whole net front on the car, including the radiator, oil cooler, and whatever that other thing is that I believe is for the AC. Anyways, since then my air will only blow out on the lowest setting possible, but it will blow out in the back seat vents when I turn that on... I'm hoping it's just something thats loose, I want to inspect the lines myself if thats most likely what it is. Any opionions would be appreciated, also any help on which lines to look for... I really need heat to defrost my windshield and stay warm, this is horrible.. please help
If you just had it fixed you need to have the body shop look at it. You might have to get your insurance involved.
If it's working in the back the problem should be in the controls or vacuum lines.
1 - 2 of 2 Posts
About this Discussion
1 Reply
2 Participants
zonie77
