1 - 20 of 54 Posts
rydr2 said:
I don't really use mine, but it is nice to have them available just in case.
It doesn't seem to be driver optional on my 06. Even with my headlights off (broad daylight) if I use the windshield washer my headlamps get sprayed. It may be becasue mine is wired so that the headlights come on if you turn on the wipers (a law in Missouri). But it's irritating when I'm just clearing some dust off the windshield because the headlamp washer oversprays and gets my windshield. I have to then manually run the wipers one more time to clear the over spray.
CTS
RobertCTS said:
So did I. I'd like to be able to disable it when the car is spotless. Haute, how do you do that?
The headlight wipers ONLY work when you are washing your windshield and at the same time the lights are on. Otherwise they don't work.
The assumption is this, if you windshield is dirty enough for you to use the washer, then CERTAINLY your headlight lenses are just as dirty or maybe even worse?
You WOULDN'T be using your windshield washers on a spotless car would you??
2003 Cadillac CTS, 2005 Cadillac STS4 1SG
The headlight washers only come on when the headlights do, so no need to stop using you windshield washer, just dont have your lights on at the same time.
03 CTS
HID stands for High Intensity Discharge
it has to do with the lighting of your car, the CTS is either HID equipped (when u get the right package) or u get standard Halogen headlights...
'04 Escalade EXT
the only time i have ever used them was when this a$$ was next to me at a red light. he had cut me off twice in a mile. how do you do that. anyways i turned on my lights and then hit hte washers and sprayed his what seemed to be freshly cleaned car. you can really get some distance on the spray when you are sitting still. nice little feature to piss someone off at a red light.
1 - 20 of 54 Posts
