1 - 12 of 12 Posts
1991 Eldorado (Gone) ; 2001 Seville SLS (RIP) ; 2005 DeVille
On my 01 Seville, the headlamps are constantly on. Reason being is there appearently is a malfunction with the Auto Lamp feature. When I have it switched on, my lamps are on all the time. If I turn that feature off, I get the "headlamps suggested" display on my DIC even when it is beyond sunny out.
Could this just be a bad light sensor? Or rather, Photocell. Or something more indepth?
Where do you think I should start? I would like to get this problem corrected mainly because I plan to get HID upgrades and just don't want them runnning constantly. Plus, I of course want everything to operate correctly. :bouncy:
As a side note..I finally got my payment book in the mail for my car. I was quite thrilled. :banghead:
1998 SLS
Hello,
I have been experiencing the same symptoms out of my 98 SLS for over a year now... I also figured it to be a bad sensor / photocell but had not gotten around to troubleshooting it yet...
Unfortunately I don't have a solution for you... All I can offer at the moment is the small comfort that you are not alone and this may be a common problem...
Also, I am troubleshooting another issue at the moment and will look into the headlamp problem while I am investigating the other... I will get back with you as soon as I find more info.
Good Luck,
Bonz
Bonz said:
Hello,
Good Luck,
Bonz
Thank you very much, I appreciate the thought.
Hopefully there is someone here who could give us both an idea of the best, or most common, place to start.
Dustin
1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
It's probably the sun load sensor. The "HEADLAMPS SUGGESTED" gives it away. It thinks it's dark out - there's not much else to suspect. The only other thing would be some sort of malfunction in the wiper circuit where it thinks the wipers are on, but I doubt it.
Good luck!
Jim
· Super Moderator
2010 DTS
Sure sounds like a faulty photo cell but don't confuse the photo cell with the sun load sensor. The sun load sensor (dome shaped) is for the A/C system. The photo cell is the flat one.
Thank you all for you reply's! Turns out it was indeed the fact I had the outosense wipers on. I feel so cool now. :banghead:
Bah
Dustin
2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
This happens to alot of folks (happened to me also), when first getting thier Caddy's. Maybe someone should post a sticky on the subject, as it would help alot of new members.
Don
I did the same thing when I first started driving my car. Since the wipers don't wipe unless they 'see' moisture on the windshield, you don't know that they're on. Now it's the first thing I check when I see the "LIGHTS ON" message during the day.
Jim
1 - 12 of 12 Posts
