1 - 20 of 36 Posts
'05 STS 1SF
Discussion Starter · #6 ·
I'd leave it in sD, turn off the traction control, brake torque it a bit and let er go!
That's pretty much what I was thinking also.
I'm not gonna be doin big smokey burnouts pre-run, so I'm not too worried about tires, or the drivetrain much either. This is nothing crazy that the car shouldn't be able to handle IMO. If this thing is supposed to drive the street day in and day out for 100-200k miles then a handfull of launches is minimal.
Also....I don't have a Mustang, I have a Caddy, and that's what I'm taking. :bigroll:
07 STS4 V8 (sold), 2005 STS V6 1SC
Let me just say that the Northstar V8 STS's are an absolute BLAST to drive. They are plenty fast, and yes they do surprise a LOT of people when they hear than engine roar to life and your car suddenly flies by them lol
As others have said, be safe/smart, keep your car in Ds, and shut the stability/traction control OFF (press, and hold the t/c button), and HOLD ON !! As for the comment about the Mustangs, in my experiences, these cars are just as fast as your common V8 Mustang (NOT the Cobras, GT500's etc. though obviously).
JUST my thoughts on the matter :)
Now, if your REALLY want to go fast, then I suggest you test drive a CTS-V. . . . . .WOW, now THATS fast lol
'05 STS 1SF
Discussion Starter · #12 ·
Well, the event got rained out. :(
Will have to wait for another day.
And I did test drive a CTS-V prior to buying my STS, fast yes, as much a car as the STS, nope.
Also, the carseat didn't fit worth a darn in the CTS.
2006 STS 1SG & 2007 STS 1SE
My drag racing buddies all change tires at the track. Other than breathing (intake & exhaust/cutout) the next mod is a racing torque converter. The more serious you get, the less able you are to drive in and race.
I might try it once or twice but to get serious you need to run consistent times and dial-in a time you will hit consistently. Why wear out a great road car?
2005 STS Lux Per Pkg
LISTEN TO ME WHEN I TELL YOU THIS !!!!
I have one of the fastest n/a caddys in the east coast.
1.Put your stock tires on the car or at least lower the rear tire pressure to 25psi
2.Make sure your floor mats are out of the car and move your seat up a lil closer than you normally would.
3. Do a small light burnout and roll into the staging lanes.
4. Put the carin 4 NOT Drive. you will run slower manually shifting as well as leaving it in any other mode trust me ive raced my car over 30 times.
5. Turn traction control off and stability control off as well.
6. Raise the rpms above stock and the 3rd yellow to green slowly put your foot to the ground.
7. Once you have rolled a little past the line mash down the gas you will get traction and keep it floored.
If you do this you will run a best time with you car trust me.
I've run 13.59 with only a K&N cone filter and an axleback exhaust.
1 - 20 of 36 Posts
