clusco said:
No, this is the original engine.
I am selling the car on the 17th of this month (November) to one of my friends so this comes at a bad time. However, the guy that I'm selling the car to only needs it for about a 2 months to get back and forth to work.
This problem occurred directly after my blower motor went out and also after I changed my motor mounts myself. I think I bent a few things while jacking the engine up.
Anyway, if it is the heater core, then where would all of the coolant be going without me noticing it on the ground.
If you were losing this much coolant via a head gasket leak in one day, the car would start EXTREMELY ROUGH the following morning on cold start-up. It would idle very poorly as you initially accelerate until all of the coolant in the cylinder(s) burns off. You'd see
unmistakable amounts of white, steamy exhaust - 1/4 gallon of coolant per day is a lot.
If the heater core was leaking into the interior, then you'd see condensation inside your windshield in the morning before the sun warms it up. Is your carpet wet at all?
You can definitely do the tests mentioned above. More advice can be:
First, remove the surge cap (engine cold only) and take note of whether or not the system is pressurized. If so, you'll hear a hiss as the pressure escapes and you'll know that the cap is doing its job and not preventing boil-over conditions at operating temps.
Next, I'd start the car and allow the system to idle up to normal operating temp. Look for any signs of dripping coolant, especially around the housing of the water pump. Once the engine heats up all the way, small leaks can be difficult to detect due to the fact that the leaking coolant can evaporate upon contact with hot engine parts at atmospheric pressure.
Another trick would be to pull your plugs when the engine is cold. If you have a gasket leak this bad, I'd expect you'll have at least one, but maybe more, wet / green plug tips. Orange if your car has Dexcool in it. They should be dry and only slightly blackened.
Good luck.
