i was told by the dealer that i have a seal that needs replacing, the one thats 2,000 to repair. the crankshaft seal. im leaking some oil, how long can i drive my 95 seville till it needs to be repaired? is there a time limit? you know the dealers they tell you asap. i just dont want to tear anything up. thanks!:)
How much oil are you leaking?
2005 CTS-V, 1994 Infiniti Q45
You should be OK as long as the oil level is ok, unless its leaking like 1qt every night.
Discussion Starter · #4 ·
at 2,000 miles it shows on the add mark then 3 quarts to put it back up, the dealers changed the oil and by the time i got home i let it set and then checked it and it was full then next morning i checked it and it read the 2nd line under full and a big puddle under the car. i know the dealers fill it up to much and i figured it just let the extra out. what do you think? does this make since?
You can run it low and that does help in some cases....But! Keep a close eye on it. The oil leak does sound pretty severe. Give it some time and see how it does running it a little low..
